Lifting weight capacity of I1???
I am sorry to say - you are wrong !!!
I am not sorry that you are getting a little bored, because I did not write my previous post to entertain you or amuse you - I wrote them because what your comment in your post were wrong and confusing for the user that had a real life problem.
The Inspire 1 will not fly above 1-2 feet (because of the ground effect) in any way or circumstances if the total weight is above 5.500 gram !!!
As I wrote earlier the way is not to calculate it but to test it in real life - and that is exactly what I did yesterday.
The wind was moderate 6-7 m/sek (13 - 15 mph) the temperature 10 degrees (50 fahrenheit) and it was 91 meter over sea level ind Denmark.
The Inspire 1 (with my configuration) weighs 3.388 g. including the 4 meter line i used to this test.
The battery (TB48) was fully charge and have only been had around 15 cycles. I used brand new props.
I used a helping hand and a precise fishing scale. I was upside down so the Inspire 1 not had to lift the wight of the scale also.
With full throttle it was maxout at 2.055 gram. But most readings was about 1700-1800 gram.
It was not possible to get continuous scale readings due to the circumstances with wind gust and a helper that was fighting to holde the scale steady so the scale never logged on a number.
3.388 g + 2.055 g = 5.443 gram max lifting power.
A note is that even that I have way over 100 hours flying with the phantom 2 and inspire 1 and I am a approved commercial drone operator in Denmark, it was very,very hard to fly the inspire 1 with full throttle - it was all over the place.
So Editor, I actually don't care about what your OPS manuel says or how you make your calculations.
If your take off weight is 6.218 gram your inspire 1 will not lift 1 inch off the ground (even with help of the ground effect.)
A realistic MTOM ought to be 5.500 g, or more likely 5.300 g and with that take off weight you will properly not be able to controle it because all 4 motors is maxout. But again I don't care if your OPS Manuel is wrong, that is your problem not mine.
That sounds like a good idea. It is ind fact pretty simpel. The more weight you make your Inspire 1 carry the shorter flying time you will have, and more difficult it will be to controle. My advice would be to keep it under 4.000 gram and try to fly it when there is very little wind. Good luck with your project - look forward to se what you can make :)
What can I say - I was hopelessly wrong and I am ashamed. I will now ground my fleet pending investigation.
I applaud your ingenuity and tenacity in this dogged endeavour to prove my calculation out by 775grams!
However, since I will never hang anything off the bottom of my Inspire over and above DJI manufactured payloads for me it's a moot point.
I do wish you lots of enjoyment flying things around dangling on a piece of string though and thank you for your 'scientific' experiment(s).
Yes you were..... - but your are forgiven ;)
Hardly necessary - but it will be nice if you try to listen to what others user are trying to tell you instead of being stubborn and hold on to something you can not prove and is wrong.
It is at least 775 but more likely 975 - 1075 gram, if you insist on that MTOM has nothing to do with being able to controlling the craft ?
The maximum takeoff weight (MTOW) or maximum gross takeoff weight (MGTOW) or maximum takeoff mass (MTOM) of an aircraft is the maximum weight at which the pilot is allowed to attempt to take off, due to structural or other limits
MTOW is the heaviest weight at which the aircraft has been shown to meet all the airworthiness requirements applicable to it
Maximum takeoff weight - Wikipedia, the free encyclopedia
DJI says that your take off weight on the Inspire 1 should not exceed 3.400 g. Don't you think your MTOM then should be 3.400 g ?
Well I do actually don't normally fly around with diffrent thing in a piece of string under my Inspire 1 - but another user was going to do exactly that, and I tried to help him and point him in a direction of choosing a different solution - I think that I and other users succeed in doing just that - but not thanks to your input in this debate.
It's hard to take anyone seriously who uses his phone in the vertical position to shoot video.
Well I actually did't see the camera/scale operator as his back was towards me, but nerver the less it was not for the nice camera quality you should se that video ;)
Reactions: andrew259
Inspire 1 - DJI Wiki
Matrice 100 - DJI Wiki
Just to put it out there, the officall wiki on the Matrice says MTOW of 3.4kg
if we apply that to the I1, assuming the same motors, and that their wiki is poorly written in english, we have just under 1kg of potential payload.
I agree. You can push the 3400 g envelop a bit, and go up to 4000 g and still maintain control. But over that it is starting to get more difficult to fly safe. Over 4500g you will have serious problems flying and if you get it in the air with 5000 g you have a serious death wish for your Inspire 1.
In my little test I had the advantage that if it got out of controle, we could either let the string loss or I could drop the flight hight a bit and gain control again.
There is an awful lot of misinformation about what the Inspire will and won't lift.The payload rating for the Inspire which is in numerous ops manuals and lodged with the CAA is 3,400g with an MTOM of 6,218g although I would not want to fly it with that loading and flight times would be severely impacted.
However, it WILL fly at those loading and is within spec so would not overload the propulsion system. I would image it would handle like a pig.
Mr. Editor,(and others)
I would like your opinion before I crash and burn. I am planing a demo flight for law enforcement agencies w/ Inspire 1 Pro to demonstrate ability to illuminate a crime scene or tactical incident using a STREAMLIGHT TLR-1 in the shown configuration (with FlyHighUSA battery mod). I weighted aircraft with payload = 4264 grams. Before I do a flight test , your opinion on stability and stress on motors? Is it safer to just fly with lone TB48?
What the hell is a 1/2 VHS deck doing on your desk other than watching old porn movies? :D L.P. you could check out the link and get some lighting ideas from this guy instead of the extra weight your strapping on, and, you can out's the bungee cord. Worth taking a look'c. Dji drone LED Light, Phantom 4 , Inspire 1 & 2
VHS is there for old times sake. I never throw anything away. The light is on with 3M heavy duty fastener, the bungee is redundancy. Yes there are lots of lights out there, but as an excop, already had the tac light....Only concerned about weight and stability.
Rodger that, just things to consider. For one, what are the consequences of having batteries (inside the light) so close to the electronics, and too, the extra weight on the top of the AC? Balancing issues? Just a thought.
My bird always balances tail heavy...adding the light only helped it a bit. The battery closeness is a good point I'll have to do a ground test and check...Thanks.
It's definitely possible to build a bird with strong light source for night surveillance. Inspire 1 airframe, however, doesn't seem to be the best choice due to relatively low payload overhead. I mean, of course she will lift a plenty of extra payload, perhaps 1000 g, but for a very limited period of time (10-15 min) and with screaming props. For such mission I will opt for something within Matrice 600 range.
Agreed. I have to use what's on hand, not what I wish I would have. Law enforcement agencies have a bigger budget than I do. This is just a proof of concept demo. Flew the test tonight with 2 spotlights at 4264 grams. Very windy but no stability problems at 60 feet. Need to pay more attention to focus. The cop with me was very impressed.DJI_0015.JPG
Reactions: Pescatoral Pursuit
Agreed. I have to use what's on hand, not what I wish I would have. Law enforcement agencies have a bigger budget than I do. This is just a proof of concept demo. Flew the test tonight with 2 spotlights at 4264 grams. Very windy but no stability problems at 60 feet. Need to pay more attention to focus. The cop with me was very impressed.View attachment 12218
Yes, very impressive indeed! I think you can get along with just one spotlight of this power easily. Curious how long your batteries last? Another idea: how about using Oly 45mm lens for such missions?
The way LEDs/COBS are being updated/refined it's not going to be long before a pee size COB will have the lumens of 3/1000w HPS.....keep inventing! Oooops, forgot the weight on the heat sink :D
If I'm using the piggyback adapter that slides over battery terminals and brings an xt60 connector to the outside and then use a y splitter to 2 11.1v batteries do I also need to wire them in series too?
Look where we are today, it excites me to think where we will be 5-10 years hence!
"Sometimes it's the very people who no one imagines anything of who do the things no one can imagine." (The Imitation Game)
1,714 of 1,724 found this interesting | Share this
In ten years Ehang-184 will be old news, just wait will you see the sleek 4 seater 190 in the driveway, OH MY what a beauty!!! Did I just say driveway? I meant to say the E-helo pad on the roof, comes extra, not included.
Dob,
I flew at 4,264 grams (9.6 lbs.), well over max take off weight of 3500g for 18 minutes with two STREAMLIGHT TLR-1 and the FLYHIGH USA battery mod (1 TB 48 + 2 1850mah). Not bad.
pushpanjalihospitals
