- Has anyone experienced the UAV (Inspire 1) start a Litchi orbit with an actual orbit center that does not match the planned center point placed on the Litchi satellite image?
- If so, what was the cause & prevention for recurrence?
Thanks.
I ask because I set a 36' radius orbit around a center point and the UAV flew an orbit where the center point did not match the point on the map, resulting in a crash into a tree. Seemed like the actual center point was off by about 30'.
Thanks.
This is why I never use anything that run waypoints etc.I ask because I set a 36' radius orbit around a center point and the UAV flew an orbit where the center point did not match the point on the map, resulting in a crash into a tree. Seemed like the actual center point was off by about 30'.
Thanks.
I'd suggest that as well, satellite imagery is not always precise enough to exactly match visual objects down to this level of precision since it may have been captured with an angle and stretched to be remapped more or less correctly.I may be wrong but you need to give yourself some leeway with altitude. Then do a practice orbit and then grab the orbit point on the map and move it to fit the orbit you need.
