Low Battery Failsafe Settings?
I've found where I set the low and critical battery levels, but I am wondering of anybody has seen a place where you set the behavior. Is there someplace where I can set it to not limit as much when it's low, or disable the auto-landing at critical?
I have not found in the IOS pilot app .9.2 a way to disable RTN or land when battery reaches critical.
I'd like to disable RTH feature at low battery.
No settings for that.
RTH at low battery however only kicks in when really necessary, I haven't had it do it yet. It's based on where the H is on the battery timeline, basically if you're so far the time needed just to come back would push it into critical then it triggers RTH, which is very good. I wouldn't see a valid reason to disable that.
Reactions: lrwskyfilms
Think that is what Smart RTH is about, set to disabled it won't RTH when critical battery warning alarm is set off....I could be wrong though.
