Need help with proper antenna wire attachment to main controller
Bottom line is I get a big fat zero for paying attention. Can someone tell me which antenna wires get connected to which port on the main controller. I know that the order from 1 to 4 is gray, black, gray black. But I do not know if the first gray and black are port or starboard side leads? Any help will be appreciated. I have attached a photo of a teardown example but there is no way to tell from the photo which leads are from the port and starboard side.
Is there anyone that can help me with this? If the front nose is slid off then you can see which plugs the antenna wires go to. The order is grey, black, grey, black. I just don't know which side the first gray and black lead come from. Any help will be greatly appreciated.
Hey
Just make sure the left ones are together and same with right ones. like Lr1 Black to connector 1 and Lf1 Grey to connector 2 on controller board.
I could be wrong but I don't believe it matters what wire goes where. They are just going to an antenna.
I have confirmed that each antenna on the gear is exactly identicle
You see I had the same question and tried it 3 different ways and it didn't seem to matter..
Hope Im right. Let me know how it works out....
glorep
