No power to esc’s after landing gear replacement after crash
Hi everybody, so I crashed. I2 started spinning like a top at 200 ft and would up with both sides of landing gear bent and a missing motor. I replaced everything and all works except all 4 esc errors. The lights on the landing gear do not light up either. It seems as though there is simply no power getting out to the esc’s. Everything is hooked up correctly and it seems the only part in the circuit that could go bad is the central board. Before I buy it, I just want to rule out a fuse or circuit breaker that I might not know about. If there is something I am not aware of, please let me know. Thank you in advance for your help, it is greatly appreciated! Thank you.
Dawsonlee
