You need to assign a button to it, or touch and hold finger on your screen and move finger round...up and down or side to side
I have changed your thread title to something more descriptive than 'Camera'just bought an inspire 1 and I can rotate the camera but can not see how to polnt the camera down, help please
Are you able to tell me where the option is. After the update the only options I show for C1/C2 are toggle screen/map and toggle screen battery.The options are still there for setting C1/C2, they just got reset to unassigned after the update, just go into the DJI Go app and set them again...
Thank you for the help ,very appreciated. I will try it out this evening and hope for success.The options are still there for setting C1/C2, they just got reset to unassigned after the update, just go into the DJI Go app and set them again...
for the other way around (27 degrees below horizontal or 63 degrees elevation) it's 1.9626 metersJust to clarify - the line A-B (or side c) would be the distance from the ground to the cameras centreline, Angle alpha would be 90, angle beta would be 27, line A-c (or side b) would be the distance from the camera to the point where the camera should aim and line C-B (or side a) would be the line along which the camera would aim, angle Gamma would be 67.
Given a height of 1 meter above the ground then the equation should be b=1*(sin27 / sin63) - which if my calculator isn't failing me should mean your mark goes at 0.5095 meters from the cameras focal plane...Depending on where you place the 0 degree reference (I've used 0 as being straight down or 0 degrees of elevation - horizontal and forward is 90 degrees of elevation)
It's actually not terribly complicated when you've seen it on the calculator - working with the 1 meter height is easiest then you just need to enter the following into the calculator... 1*(sin(63)/sin(27)) and hit equals, reverse the 27 and 63 to go the other way...Thanks so much for the detailed response. I was hoping to avoid such complicated geometry, but so far it is looking like the only option. Someone really needs to develop an app that can do this as an overlay. I can't be the only operator that requires this function.
Thanks again, and if I find a simpler solution I'll be sure to share it here.
