Patch Antenna Cable
I managed to crunch the male end of the Patch Antenna for the Cendence RC. Does anyone know if the cable can be replaced? There is actually a female port on the little grey box which I assume is to attach a second controller, although I have know idea why you would need do this. Hoping perhaps there is a cable with male plugs on both ends that could be used if there is no replacement. Reallllyyyy hoping I don'y have to replace the whole antenna... ouchIMG_8474.JPG
Inspire 2 gps unit has the same connector, $30 on eBay. Contact DJI, ask if they have the connector, probably not, probably won’t even repair the antenna, tell you to just buy a new one. If you use the patch antenna often, $30 might be worth it.
