I travel quite extensively with an
I2, and you most certainly will have to check it. This is the case I use:
HPRC Wheeled Hard Case with Foam for DJI Inspire 2 INS2-4600W-01 and while pretty large, it's the most durable and well-made case I've seen. I use a lot of HPRC cases, and they all have the same high-quality engineering, and solid warranty (which you will NOT get from a Pelican case if damaged in air transit. They do not warranty
any damage incurred in air travel.... don't get me started on that one) I would not want to trust the case the
I2 came in over time. For a few trips maybe, but it's just not going to hold up over time. Plus, the HPRC is big enough to get several lenses, two chargers, rotors, filters, the gimbal can store separately (yes, you should take it off for travel) and even some slots for smaller iPads or other monitors. While you can get 4 sets of batteries in here (5 if you have a set on the
I2), you cannot check those and they
must be hand carried in the cabin of the aircraft. All airlines have their own policies for Li-ion batteries, so make sure you know the policy for your carrier. You should also discharge your Li-ion batteries to about 15-20% for safe travel. I've also used this case to ship my
I2 via Fedex. Keep in mind that some couriers also have Li-ion limits on flights,
especially internationally. I was going to fly my batteries home from a recent trip to Turkey (because of all the electronics restrictions on flights from that part of the world) but Fedex would not allow more than
two batteries per case from there. I had 5 sets, so that meant 5 shipments internationally just for batteries! I ended up coming home via Amsterdam with everything with me and had no issue. The case is big, so yes, on some carriers you may be charged for oversize unless you have a legitimate media credential which will get you a special rate on many carriers domestically but not internationally. I have never had a problem with the size of this case in the automated baggage handling system, and it has always showed up with regular bags not the oversize bin. Hope this helps!
