Remove Height Limitations
If you are commercially certified, there are instances where limits can be adjusted and still be altitude compliant ie working around a tall structure. "Part 107 limits your altitude to 400 feet unless your unmanned aircraft is flying within 400 feet of a structure (in which case you may not fly higher than 400 feet above the top of that structure)."
ericaharting
