Secraft Trays, CrystalSky, Hand Catch Handles and More New Accessories
Florida Drone Supply
Approved Vendor
www.floridadronesupply.com
Lots of new things to talk about and consider over at Florida Drone Supply...here is a link to all of our newest items (photos also attached):
New Items
Secraft Transmitter Trays for Inspire (1 and 2) - Dual Monitor Mount Available
If you have not seen or used a Secraft Transmitter Tray for your remote controller yet, check them out. They make flying very comfortable and use an adjustable 2 point harness that clips onto the left and right sides. Plus they have the option of being set up with dual monitor mounts. They also have the option of being the mounting point for the DJI Focus Handwheel. They start at $89.
Secraft Hand Catch Handles
A great little accessory for anyone flying from a both or other moving platform that needs to hand launch or hand catch. They also are excellent for being used in dirty or dusty locations - helping to keep the dirt and debris off your camera lens. Overall they make hand launching and hand catching your Inspire easier and safer. $44.
CrystalSky Monitors
Yes, they are finally going to be shipping soon. They are available in 3 variations and ranging in size from 5.5" to 7.85". Prices start at $469 and go up to $999 for the largest and brightest version. Pre-orders are being taken now and the first units will begin shipping fairly soon.
Go Professional Inspire 2 Cases in Stock
If you have been trying to find somewhere with the Inspire 2 Go Professional cases in stock - we have them. Its a well made case, hold 12 batteries and multiple radios and charging systems. $549.
Cendence Remote Controller for Inspire 2 and Matrice 200
Just announced is the new Cendence Remote Controller. For everyone who comes from a professional RC background and has wished DJI had a different remote controller, this looks like it is going to be a great radio. It has multiple programable knobs, levers and switches and should open a lot of possibilities for us. They are available to pre order now. $999.
High Gain Antenna Tracker
DJI also just announced the Tracktenna - a high gain antenna tracking system which in some scenarios can increase range to over 6.2 miles. Pricing and availability has not been released yet.
Good stock of other accessories too
If you are looking for other accessories (TB50 batteries, 2nd radios, GPS modules, SSDs, etc) we have good stock on most everything.
Thanks for checking us out!
Michael
www.FloridaDroneSupply.com
Will the 7.85" CrystalSky monitor fit on the Secraft iPad mini 4 holder I purchased from you or will I need to go to the larger one? I think I bought the medium size. Flying down here in sunny south west Florida would you recommend the 1000 or 2000 nit monitor?
@SanCap - Yes, you have the medium (holds the iPad Mini). I will double check the dimensions of the large CrystalSky and confirm if the medium will hold it. Also, we have a dealer demo of a P4 Pro Plus and the screen on it is really good in the daytime sun - but having twice that brightness would be substantially better. We are ordering them all in and you are welcome to give both brightnesses a try - but I think you will end up with the brighter one...just a hunch.
OK so the Phantom 4 pro plus screen is 1000 nits. I have seen that but I think I would want the option to go brighter. It the brightness adjustable on the CrystalSky monitors?
Good question on being dimmable...I do not know that answer yet, but the user manual (attached) shows that the monitor has a small light sensing port below the screen in the center. Its possible that it is capable of setting its brightness to auto based on the ambient light around it - but this is not confirmed yet. I am messaging someone at the DJI booth at NAB and asking them to go into the settings of the device and see what exists for brightness setting options. If you think about it there must be some setting because a 2000 nit monitor at full brightness would be very, very bright when used at dusk or in the evening.
I'll post a confirmed answer as soon as I get one.
Reactions: SanCap
I found this in the CrystalSky FAQ.
6. How is the CrystalSky monitor’s brightness adjusted?
The CrystalSky monitor’s brightness can be adjusted manually and automatically. When set to adjust automatically, CrystalSky will adjust its brightness based on the ambient brightness detected by its light sensor.
Reactions: SanCap
Hi I bought the Inspire 2 case from Florida Drone supply ,I am very happy with it, you can fit a lot of items, is a must if you travel on airlines
@jlo - glad you like the case. We still have several of them in stock and have another shipment of them on the way. The next shipment contains some travel mode versions as well as the landing mode versions we already have.
Hi Florida Drone supply do yo have the 60mm sigma
I gave it a try with my I2 X5S camera and it has some issues. i would like to list the issues and cross reference with anyone that has tried this lens
1 The lens is brand new from B&H of the box has what it appears a loos internal element that moves front and back, as I tilt the lans, I though it could be a floating element and thats what its suppose to be like....but
2 when I install the lens on my X5S camera a strange pattern shows on the picture
3 the lens focus ring does not work
4 the lens struggles to find focus trough the app
5 I can not switch it to manual focus
6 I have the DJI focus wheel and it does not works with this lens
7 if I install the lens on a Panasonic GH4
its works perfect !!!!!
any thoughts ?
any thoughts ?
That lens is not supported on the X5S camera system.
New Items
CrystalSky Monitors
Michael
I assume that the 7.85 Crystal Sky will not fit into the arms of the Mavic Pro controller the way that the ipad mini does because it is so much thicker with battery. Is that correct?
Will the 7.85 2000 nit Crystal Sky fit into the standard monitor holder on the inspire 2 controller or will a new holder be required?
Does Florida Drone charge a card when a pre-order is made or when order is shipped?
You are correct about the Mavic.
The CrystalSky Monitors will require this bracket to attach to the existing radios:
DJI CrystalSky Remote Controller Mounting Bracket
Our pre-orders are charged at the time of purchase...but hopefully the time from purchase to shipping will not be a very long wait.
May pick up one of those trays for the I2 with the shoulder harnesss. I will be in Marco Island, FL from May 6-13. Would I be able to come to your store to pick up? Or if I ordered tomorrow is there free shipping to 90272 and would it arrive by May 5? Thx
Thanks @mpaerial - I think you will really like using the Secraft trays for an Inspire 2. They are great.
If you can order in time for us to get it shipped tomorrow for you there will be plenty of time to get it to you before you go...
Michael
You will like the trays, I have 2 of them, let me know when you are in the area. Are you on vacation or doing a shoot? I have lots of good local boating info. Here is a google map I created of all the restaurants you can boat to in our area and more. Southern Boat To Restaurants I am sure I have missed some.
LavernePre
