SOLVED No signal. fail upgrade
Hello everyone,
i just received inspired one 1 day ago.
Check the inspire the camera and the app and try to shoot photo and video and everything works well.
Check Overall status and he ask me for upgrade Rc and aircraft.
Followed instruction to upgrade.
download firmware
1-Put 1.2.0.17 inside microsd.
2-then inside camera (off)
3-switch on the RC and the app.
4-Switch on the inspire.
Message on app.. UPGRADE firmware... I push OK
Then no progressive bar is showed but the inspire start to upgrade ( i supposed from the sounds from the inspire)
After more than 1 hours nothing appends and my colleague switch off the inspire.
Then i put se micros/usb in the RC and update
Now the problem.
When i switch on the inspire the yellow light flashes but the app say no signal.
Try to repeat step 1 to 3 but always nothing append and the yellow light continues to flash.
I supposed something go wrong during the update and the switch off.
Please HELP
Your remote is likely not updated yet.
Did you read the upgrade manual? Did the Inspire do the correct sounds?
You may also need to bind the Tx to the Inspire. The instructions are in the manual.
Thank you very much. Problem solved. i have two transmitter and I was trying to connect with the slave Tx. Update the master Tx and now everything works.
