ssd pro res help
can you import from ssd to pc straight off the inspire 2 ?
I just got a 480 GB SSD card today and im waiting on the SSD reader. can you plug into the pc and get files off that way?
Also , why do you need a SD card in to use the SSD ? sort of defeats the purpose since it records to both , unless it( i hate to sound like a total idiot BUT) it records 5280 on SSD and the other setting of 3840 on the SD card ?
so when you hit the play button in the app it shows the SD card version of 3840 , will the 5280 only show on the SSD reader ? ( dont have yet to know ) because when i play it, its in the 2.11:1 format?
also any tips on settings would be appreciated .
Reactions: MrTVR
You plug into a PC for updating with Assistant so there is no risk in trying to see if your drives mount. I read and adhere to instructions never to pull a cinnessd out of or insert into a powered craft or reader. It's too much $$ to blow the memory from a spike.
Here's some videos from a youtube search of dji cinnessd workflow:
dji cinnessd workflow - YouTube
Reactions: dasko
UrbanScroll
