I wish I could help ... Try to put a bit more effort describing the issues, possibly in English ...1 Gimble wheel right hand side say locked ?
2 What video software is worth it , anyone have light works ?
3 Any one know the best setting doe this lens Olympus M.Zuiko Digital ED 45mm f/1.8
Hoping for help thanks in advance
Oh, you made my face red ! How did you figured out what Nick meant by "anyone have light works?"? Or what is "RH gimble wheel"? I think he assumed that RH wheel on RC is controlling gimbal yaw, since LH wheel does control tilt. That's not the case with standard DJI RC. Multiple other functions of RH wheel are activated by pushing it first (unlocking), as described in manual.One more thing Nick- the 45mm is the most sensitive to weight imbalance, so spend some time getting the right counterbalance for the ND filter(s) you want to use. And if you want shallow DOF, you'll want a few ND options. I find a 3 stop ND, a Polarizer, and a 6 stop ND , each on their own, or in combination, cover most uses. If you add a lens hood to control flare, you can end up needing quite a lot of weight on the back of the gimbal.
