Two issues: can't update firmware + RC not linked to M100
ok, here is the fix.
if you have a camera (x3)
download the X3 camera update (August 2015), install, then download the current update (April13 2016) install. Should allow it to recover and work properly, then you can use the Assistant software to connect to the aircraft.
Thank you. It looks like I will have a camera arrive tomorrow. So once that comes, I should be in good shape. Glad you got yours working.
Smootar, I pulled it off the SD card that I put in the camera.
I have the same problem when connecting my PC to the aircraft, they just do not talk to each other.
Do you have a Video Decoder? That would work ILO the camera.
Thanks Todd, it sounds like DJI is good to work with. Happy flying!
CharleyBet
