Unusual behaviour Cendence + 7" CrystalSky monitor
Hi! Just hoping for a little feedback or workarounds regarding a few issues i'm having. My setup is:
  • Inspire 2 with X7, dual Cendence remotes, 7" UB Crystalsky monitors. All items have recently been updated to the latest firmware.
    - Cendence loses it's settings: changes from PAL to NTSC, video to stills mode, frameguides disappear, colorspace changes to REC709 etc..etc..
    - Ocasionally on a reboot, under the manual video settings the aperture sets itself to T1 (strange as the DJI DL lenses max aperture is 2.8). Any attempt to change the aperture immediately reverts it back to T1. This is accompanied by a constant manic flickery change between stills + video mode.
    Any enlightenment on these issues would be gratefully appreciated! Thanks
Thanks. As soon as i'm back in the workshop i'll check and take some snapshots
I had the same problem.
You have issue because you mount lenses wrongly.
Solution: when you mount a lens you need to lock it and do little reverse rotation with you hand on lens to be sure that all DL-lens’s pins are in contact with X7’s pins.
If you don’t do this little reverse lense rotation you will continu to have bug.
( after that you need to give Inspire 2 time to recognize the lens )
