Using Ipad mini as second monitor
What cable do I need to connect my inspire 1 controller to my Ipad mini to use it as a second monitor.
You can't.
IPads do not accept video in via HDMI protocol
There are solutions like using a Terradek cube or similar and streaming via WiFi etc
Litchi... DJI can't seem to get it together software side.
Sent from my SAMSUNG-SM-G891A using InspirePilots mobile app
Litchi is a not a solution for second monitor...
@heygeorge Assuming your first device is connected to your Inspire controller is a device connected by USB then the best option you have is to either get a second monitor that can connect to the same remote by HDMI or get a second controller that you could connect the iPad Mini to using USB. Only one USB device can be connected to a controller at one time.
Reactions: The Editor
Actually you can cast to another device wirelessly with litchi and iOS only... waiting for the feature on android myself.
How is that not what's being asked for?
I was litchi for iOS but. I also use an android and iOS and go with this
I'm hoping for a low latency stream with android to android directly in Litchi, in the Vue stream, you can enter cardboard mode and control the gimble with VR goggles while a pilot flies and controls the camera settings from the tablet as usual.
VanitaYaga
