Weak signal
Took the inspire out for a quick flight around the neighborhood everything going fine.Then i look down at the screen and it said weak gps signal turned the bird to head back home and screen gps signal was fine.any idea what caused it and what should i do if it happens again.Thanks
Sent from my SM-G925P using Tapatalk
There's a lot of variables here that could play a role in gps! Location, magnetic interference, if your antennas not in the position they should be? Your radio has a gps in it too just like the i1 so it could be radio gps interference and not the intended gps?
The bird look to be flying ok didn't notice any problems with the bird just that weak signal notice.thanks for the advice
OllieLoane
