X5 Gimbal Disconnected mid flight
Hi, we use and inspire 1 pro at work and whilst out with it the other day the gimbal kept 'disconnecting' mid-flight, the inverted commas are because we still got a view through to both me (the pilot) and the camera operator and he could also still control the direction of the camera with the second controller. We could not record or take photos and the info from the camera switched to N/A, this would happen occasionally and then it would reconnect and continue to function until it happened again.
Has anyone had this happen to them? Anyone know how to fix it?
Reactions: Mad_angler1
Going over the connector pins with a small ink eraser has pretty much put that problem to bed for me. Just be carful in the X5 pins and work from the center out or you'll bend them.
VanitaYaga
