No, I've not had the chance to sit and think out and do a proper bench test.
Yes, you'll always get a maximum of 12 bits of information in the image as that's what the camera is capable of recording, but it will have to use 16bits to record those 12 bits in as that is what the image processing software expects to see. If you've a Dslr camera that records 12 or 14 bit images, then they'd do the same, store it in a 16bit file. The accepted standards are either 8 or 16 bit. So photoshop etc will either report 8 bit or 16 bit files depending on the format used.
As to the difference in SSD and sd raw sizes, I'm musing out loud here.... no definite proof as I haven't an inside line to DJI tech, and I've not sat down and checked any of this out....
- The SSD RAW is recorded when the photo mode is set to 14fps burst or infinite burst, so it's pumping through a lot of data. It could be that in order to sustain the burst frame rate without causing buffering, the DJI techs decided to put in some compression.
- Despite what the ssd file says, it could actually just be giving 8 bit raw instead of 12 bit.
- most Raw files also include an embedded preview jpeg file, I've not checked but it could be that there is no embedded jpeg preview - that would save space and increase speed all round.
- or, simply, There could be a cock-up in the coding for the SSD burst Raw files which is resulting in the lower size, and also the problems you're getting with Raw Therapee.
Out of interest, I haven't yet purchased the CinemaDNG or ProRes licenses (I figured I'd wait on to see how DJI were handling crashes and transfers first!), so I can't check this out... are the Video CinemaDNG raw files recorded for each video frame the fuller 42MB each, or are they smaller?
God knows if any of that makes any sense.... it's late night here
