It is exactly what I expected. I have done some test shooting with the I1 in my hands (props off) and that gave the same result. The Osmo grip will not change the gimbal capabilities all of a sudden.It's really bouncy as you walk, I need thought it was supposed to be like that, I thought it was supposed to compensate for such movement
The gimbal can compensate for the orientation of the Osmo's handle relative to the camera. However, it cannot compensate for the (rapidly changing) height of the Osmo relative to the ground. The bounce is most noticeable with objects in the foreground...the trick is to either focus on objects in the distance, or move around on something that has wheels.It's really bouncy as you walk, I need thought it was supposed to be like that, I thought it was supposed to compensate for such movement
You are correct. However, with the Osmo, you can easily get much closer to objects than you can with the Inspire 1. I recently watched a video where someone used the Osmo to record tree branches and leaves up close...which (thanks to the focal point of the camera) had an almost 3D look to them. I decided to try and do something similar here.It is exactly what I expected. I have done some test shooting with the I1 in my hands (props off) and that gave the same result. The Osmo grip will not change the gimbal capabilities all of a sudden.
Must say, it wasn't bad at all to carry the I1. I had a separate camera operator walking behind me. I needed to switch off the adaptive landing gear though. But the Osmo grip would be a welcome add on for sure.
No, I haven't tried that actually; I may have to give that a shot.@dspear237 were you holding the trigger down while walking? I've been taking my Awesom-o (OSMO) running alot, and I've been quite impressed with the performance of the system.
The Awesom-o is SO much easier to run with than a Movi!
