Battery Mod Info
I am now of the firm belief at this point is that the DJI and Multistar batteries aren't good aux battery candidates because of their low C ratings, unfortunately. My testing has born that out as well.
I'm a little confused as well, wouldn't the DJI battery have the exact same C rating?
Damon I guess I'm a bit confused I thought we were looking for low C batteries because you got more power per wait out of the low c .I thought the general consensus was the DJI 47 and 48 batteries had very low c?
Low C batteries are much lighter, which is their allure. But with the DJI TB4X batteries as the main battery, low C batteries as aux batteries just don't get used properly and drain at the same rate, even other DJI TB4X batteries (ie identical). I suspect it's due to the charging logic in the TB4X but I don't know for sure. I do know the higher C (20C+) work as expected and drain in parallel with the main TB4X battery.
I think we're zeroing in on the sweet spot. Seems the sweet spot might be 20C, paired with a TB48 main battery, and either
  • 2 X 6S 2800mAH (or as high as you can find/afford) in the 370g neighborhood, or
  • 1 X 6S 5600mAH (or as high as you can find/afford) in the 740g neighborhood
Depending on your mounting preference.
These are 30c
Description:
Product type: Rechargeable lithium polymer battery
Battery parameter: Lion Power 22.2V 2800Mah 30C
Battery capacity: 2800MAh
Continous discharge rate: 30C
Battery size: 11.7 * 3.7 * 4.3cm / 4.6 * 1.4 * 1.7in
Battery weight: 379g / 13.4oz
These are 30c
Description:
Looks promising! Test and post! Are those the eBay ones?
tcchow - I'm very impressed by your lipo brackets you fabricated for this mod. Are you in the US? Would you be interested in manufacturing/selling any additional brackets for those of us with limited skills and resources? lol
sorry for late reply. here are the link
#淘⼝令#长按复制这条信息,打开手机淘宝即可看到【聚龙模型 DJI大疆 Inspire悟1手持放飞器 脚架加强配件 云台保护 】http://b.mashort.cn/h.THi1h?sm=76f9a0
Thank you! Do you happen to have a link to the bracket that you have mounted to the lower body as well?
sent me your email, I give you the Auto CAD file. Actually I am still modifying the arm brackets. the under pice are taken off
Seems like a lots of gear, weight and hassle to hold two batteries.
Why not just use 3M Dual Lock like I am doing at the front of the battery compartment? Safe, cheap and weighs nothing.
what I am trying to do are balancing left and right, front and back. That piece of alloy give me enough rooms to put the battery go little bit forward and backward and get to the balance I need.
How much do all the pieces and screws weigh per side?
CodyF
