Battery Signal Error
Anybody ever seen "Battery Signal Error" before?
I've just seen it on a flight about 5 minutes ago. It only showed for a couple of seconds but I landed it ASAP to be on the safe side.
Check the four spring data pins on your bird. Make sure the contacts are good and that there is no foreign debris stuck on the contacts. Check battery status and condition with in the app. Have you cycled the battery? How many flights on battery so far?
Gaitandudek
