Cannot get the I2 to power up after battery removal
After trying (unsuccessfully) to pair my aircraft with the RC, I attempted to shut down both units. The aircraft wouldn't stop so I ejected both batteries. Then I couldn't restart it so I switched battery pairs and it started immediately. Is this "normal"? Thanks.
A long while back I had to replace the part that holds the batteries. I had one side that would sporadically not show power even thought the battery was locked in. You most likely have an intermittent connection problem. If you push the power button on top of the I2, the battery lights (for both batteries) should light up and show that both batteries are in fact connected.
Thanks for your reply - and your helpful info. I appreciate it. I'll watch for those battery lights in the future. Thanks again.
fraudschemesexamdumps
