- Joined
- Mar 18, 2015
- Messages
- 451
- Reaction score
- 92
I feel your pain. At least it’s easier to control iris and shutter. The main advantage is the fact I can use the right thumb wheel now to control pitch of camera. I don’t know why the other controllers don’t have that option to switch as most of us are right handed. I find the left wheel difficult to control pitch with left hand.Working fine for me.
The main frustration is the battery, which depletes much faster than the one on the standard Inspire 2 controller. It uses the same battery as the CrystalSky monitor, which I also have, and which also drains quickly. You definitely need two batteries for each if you will be flying for more than an hour or two.
I am also frustrated by the button labeling; for example, "BD" is the button to bring down the landing gear. And there is no easy way to label it, as there isn't much room around the buttons.
You can assign another button if it feels more comfortable. From my experience it is good to experiment a bit from begining untill you find the most logical button configuration but then stick with it. And remember that you do not have to assign a function to every button. I only use those which help in day to day operation. Your brain will soon memorize the functions and it will all become automatic. I do not find to be a good practice to keep changing the buttons all the time. It tends to confuse the muscle memory..Working fine for me.
Because the right wheel on standard controller is stepped for changing camera settings. Only the left one is smooth and stepless, so you could not use the right wheel for pitch control.I feel your pain. At least it’s easier to control iris and shutter. The main advantage is the fact I can use the right thumb wheel now to control pitch of camera. I don’t know why the other controllers don’t have that option to switch as most of us are right handed. I find the left wheel difficult to control pitch with left hand.
