Flir XT Inspire Gimbal Alternative?
Question & Thoughts…. I was considering purchasing the Flir XT R 640 30Hz for my Inspire. I see they are running in the $11,500 range.
The Tau2 camera alone is about $6,900 making the gimbal $5,100 which seems a bit crazy.
Got me thinking about an alternative. What about a Vue Pro R 640 30Hz ($4,700) on a 3DR Solo ($400) with an OEM Cameras Flir/Solo Gimbal ($1,500), including another aerial platform.
That's about 1/2 the cost of the Inspire Flir XT gimbal setup. I really couldn't find an appreciable difference between the Tau2 & Vue Pro R specs to make that a deciding factor.
I suspect many will say you can't compare the Inspire to the SOLO and I agree, however I just need to get the IR camera aloft and really don't see a major advantage in using the Inspire for the inspection work I have planned.
Having another bird is also something to consider on the plus side.
Any thoughts…. Am I missing something…….
After some realization, I realized the solution...
Pay $17 000 (not incl G.S.T.) NZD for the ready made ## DJI XT ##
Horrifyingly ,,, that's the 9 hz 336x256 !!
And then still hopeful you are over reacting,
Try flying ,,at any speed sub 1km/hr at
##### 9 hz ####
But it's a ($17 000) solution...
##### 9 hz ####
Well - as you say - its a solution. Not really good quality or inexpensive - but a solution!
The 30hz is a big deal for flying - keeping your image much more clear.
havemeds
