Footage Wobbly like roll axis is off?!
atortphotography.com
My footage seems to be constantly as if my roll axis is off or something and not sure if a setting or what’s going on. I read something that there is a setting for yaw and should be sweet to 0 or something? Please help really messing me up! Thanks
An example of this is in this video every clip is having this movement!
Try calibrating your gimbal.
Check your props, make sure they aren't damaged. I had a similar thing happen a few years ago. Turned out one of my props had the tip very cleanly clipped off. Probably happened closing the GPC case. Hardly noticeable when you looked at the prop, but produced similar footage.
Reactions: Donnie Frank
ziamedicalcenter
