Gimbal and Control settings for I1 V2 with X5 camera
Verona
Hello everybody. I turn to those who use the drone for shooting and video.
Can you tell me your gimbal and controller settings?
Keep in mind that on my X55 I mount the whole range of M-Zuiko lenses 12/17/25/45mm (all with UV filter), and i just try a lot of tips for jello problem of 45mm!
Tks to all
PS: in this moment I am feeling well enough with this gimbal setting from @FlyHighUSA
Gimbal pitch exp 3
Yaw exp 5
Gimbal yaw smooth 7
Pitch smooth 6
Gimbal synchronous follow ( yes)
Tks to all
Gimbal pitch exp 3
Yaw exp 5
Gimbal yaw smooth 7
Pitch smooth 6
Ironically, just did a shoot yesterday with the exact same rig.
I use two configuration profiles. One is a "faster" profile, which is my goto profile. The other is for more precise movement, and is therefore a bit "slower."
Goto profile:
Gimbal Pitch EXP: 50
Gimbal Yaw EXP: 50
Gimbal Yaw Smoothness: 20
Gimbal Pitch Smoothness: 20
More precise or "slower" profile:
Gimbal Pitch EXP: 40
Gimbal Yaw EXP: 40
Gimbal Yaw Smoothness: 25
Gimbal Pitch Smoothness: 25
And then I have my "madman" profile for super action stuff:
Gimbal Pitch EXP: 100
Gimbal Yaw EXP: 100
Gimbal Yaw Smoothness: 15
Gimbal Pitch Smoothness: 15
All profiles have "Gimbal Pan Follow" Enabled
Here's what we shot yesterday using my "goto" gimbal profile. Worth noting, it was 33° with 10-15 mph winds and gusts up to 19 mph.
Goto profile:
Gimbal Yaw EXP: 50
Gimbal Yaw EXP: 40
Gimbal Yaw EXP: 100
Donny you set only gimbal or stick too?
