Go Professional Inspire 1 Travel Case
I have a used DJI Inspire 1 Go Professional case for sale. It fits the Inspire 1 snuggly in travel mode along with two controllers and 6 batteries as well as space for several extras. This model is meant for the Zenmuse X3 camera system. I am asking $200 plus shipping.
I have traveled with it a bunch so the outside of the case shows a number of cosmetic scuffs. The wheels also got slightly bent while traveling as checked luggage, but they still roll along fine.
All of the latches and the interior of the case are as good as new.
Definitely let me know if you have any questions. In case you are curious I needed to upgrade to a different model when I changed the camera system on my inspire 1. Otherwise I would still be happily using this one.
Item Dimensions 12.5 x 20.83 x 31.52 inches
Description from Amazon: Brand new is $430
The Go Professional Cases INSPIRE Watertight Hard Case for the DJI Inspire 1 Quadcopter provides a handy solution for storing and transporting your quadcopter and its accessories.
In addition to the aircraft and built-in camera, the case will hold two transmitters (radio controllers), six flight batteries and one charger, the main set of props plus a spare set, a monitor with a screen up to 10", and features three cavities for miscellaneous items.
The DJI Inspire 1 case is ready to keep your Inspire 1, Batteries, remotes, monitors and all accessorizes safe and waterproof.
Features:
Custom closed cell foam interior
Industrial strength injection molded pull handle
Four wide set in-line skate style wheels for easy transport
TSA accepted key locking latches are available
Padlock holes include stainless steel padlock protector clips
Waterproof and dust tight design (MIL-C-4150J)
Molded-in hinge for added protection
Trigger release latch system
Snap-down rubber over-molded cushion grip handle
Ambient pressure equalization valve (MIL-STD-648C)
Resistant to UV, solvents, corrosion, fungus (MIL-STD-810F)
Resistant to impact damage (MIL-STD-810F)
VanitaYaga
