I1 won't stop updating
I did an upgrade earlier today and I believe it took fine but I forgot to remove Micro SD card before doing a power reset. It's been an hour and it's just doing
Dee da deet, dee da deet.
What should I do now?
Sent from my SM-G920V using Tapatalk
If it's really the sound that plays when the firmware is done installing, it'll continue that pattern until you turn off your Inspire. What happens when you restart your Inspire?
Finally just shut it off. Seems fine. I will test tomorrow
Here we go again. Trying to update to the new firmware. It's been 45 mins still getting deet da deet da deet.
Nope you get four d d d d when the firmware is updating then three d d d's when it's finished.
Turn your inspire off then back on & all should be ok.
Reactions: dirkclod
Ahhhhh. Ok. I'll check it again. I had to pop out for an appointment
I updated mine yesterday, inspire/batteries/RC.
Updated with no problems, just check out SanCap's link above. Should help you out.
Once you've got that under your belt, remember to calibrate (condition) your batteries but one step at a time;)
Reactions: dirkclod
Ok I thought u needed to remove the micro sd card before rebooting. Thought it would restart the upgrade in an endless loop
Nope - if it has already updated and you leave the file on the MicroSD card it will simply abort at start up and not update again - basically it will ignore the firmware on the card
ziamedicalcenter
