Inspire 1 shaking on braking
My inspire 1 vibrates(well quite literally shake) the gimbal when it's braking or ascending rapidly. this also causes a jello effect in the footage when this happens. Otherwise on hover and moving forward or backwards everything is mostly smooth.
One leg at the T joint was a little shaky and i added some rubber there to make it a little firmer. This slightly helped the vibration.
I am wondering if it's maybe the props that are causing that. they are the original self tightening ones. seen some use.
Try another set of props because if there is a unbalanced prop it could lead to catastrophic failure like a prop cracking or breaking off and if you are in flight it is bye bye birdie.
If they are the original props they are plastic and should be changed out once a year by default in order to prevent any issues. Plastic wears out over time and if you think about the props are like airplane wings and are constantly being pulled and pushed every time the quad is in flight.
JessikaTre
