- Joined
- Apr 6, 2017
- Messages
- 11
- Reaction score
- 0
- Age
- 53
I have a Cendence remote so no manual landing gear switch. Mine’s stuck in landing mode. Glad I’m not on location having to pack it up right now.
The Cendence does not have a landing gear switch? How do you control it then?
I am engineer and since I first got the I2 I figured out that the way this entire landing gear transformation has been designed and made it would lead sooner or layer to premature wear and subsequent malfunction. I addopted the practice to ALWAYS lift the I2 off the ground during the transformation, so there no undesirable forces against the motion. IMHO it is matter of type of surface the transformation is done on which will determine the longevity of the mechanical parts involved. If you are doing it regularely say on grass, dirt or rocks where there is high probability that the legs of tge I2 get stuck, the forces the little motor needs to overcome to complete the raising are huge and the motor, the worm and the electronic control unit suffer badly which will lead eventually to failure of the components- mechanical or electronics. That is what my engineering brain is telling me. Not related directly to the issue of this Thread but something to consider...now my landing gear not working anymore... even in travel mode it won't goes to landing mode.. i have to manually use a screw driver to drive the worn drive... Oh my GOD... i have few job this week .. and DJI NEED to me send back my i2...
Components do fail, that is a fact of life. I guess in your case it was unrelated to what I am referring to. All I am saying and perhaps advising to all I1 and I2 users is that if you want to prevent premature failure of the servo system, always lift the aircraft off the ground when doing the "travel to landing position" transformation. You will do the aircraft a huge favour and it will thank you for it with longer life!!I don't disagree... you can HEAR that servo laboring sometimes - especially on the Inspire 1. I have a landing mode case and I never put it in travel mode or transform the unit when not flying, and still the landing gear servo failed on me. All well, again -- mine was fixed pretty quickly for free under warranty so I cannot complain about any of that.
TBH I have always used manual switch for that. I like to be in control of the craft. I also fly with all warning off including OA and VPS, so all this is gear issues are of no consequence to me and I do not feel like testing this bug with my own I2. One thing I will mention though, and it surprised me when it happened first time, is that even with OA off I still get audible beep warnings when flying close to subjects like for example flying towards a tree and then raise the craft and fly over, shots which I like to do quite often.@Advexure@ Thanks a lot for the useful information you are posting. Can you confirm whether or not the landing gear bug reported by the OP (Jason Boucher) in January 2017 has been fixed in the latest firmware? This bug seems to still be present even in the very latest firmware according to my own testing today.
Ok I'll give the manual method a try. Thank youThat's the exact same scenario where my landing gear stuck. Gear coming down and then you increase throttle. I believe it to be a firmware bug, but noone else believes it and I just get dissed every time I mention it. I wound the landing gear down using the screw underneath the I2 and have disabled auto landing gear. The landing gear works fine under manual control.
