Hey there, I'm looking for dimensions and all possible info as well, my screws felt apart....
I tried that and failed - which way did you cut - did you try and cut across to cut through the screws ?I used a Dremmel tool for the cutting of the prop mounts.
The stock screws are glued in place.
Heat the screws with a very hot soldering iron to break them loose from the DJI glue.
This method is true for both non-stripped screws, as well as stripped ones like your's.
I tried to install carbon fiber blades. I got 5 out of the 8 screws out then ran into the most stuck screws I ever come acrossed! I broke 4 T-8 tips trying to get 1 screw out. After talking to my mechanic, going to the auto parts store for help (they didn't even carry T-8 tips, I bought some more tips and tried the heat method. I can confirm that if you apply about 40 seconds or more (I used 40 seconds) of heat and then immediately start to unscrew them with firm pressure they will slowly come out. I even was looking at replacement motors in case I ran out of options (The 4 screws that hold the motor in place probably have loctite on them too).
I picked up a heat gun and have been trying this method. 2 set came loose easy the other 2 are like hardened steel. I've tried the heat gun method twice so far, once on low heat the on high setting for about 25 seconds. I'm paranoid about melting something! The motor was very hot to the touch but the screw would not budge at all. Do you have any advice? Thanks.The stock screws are glued in place.
So not to strip the head use a rubber band over the driver. Vacuum motors after removal and be mindful of putting pressure on the feet.I picked up a heat gun and have been trying this method. 2 set came loose easy the other 2 are like hardened steel. I've tried the heat gun method twice so far, once on low heat the on high setting for about 25 seconds. I'm paranoid about melting something! The motor was very hot to the touch but the screw would not budge at all. Do you have any advice? Thanks.
EDIT: I just noticed how old this thread is.
I've totally F**** it! Melted the plastic. Got one screw out the other is completely stripped! Help!!!
I kind of at my wits end, here. I stripped away all the plastic but the screw will not budge. Not at all. I've been trying for 2 hours and it just won't move. I put a soldering gun on the scrw but that did nothing. Could use a little help. Thanks.Relax don’t panic!
You still got options. Cut the plastic up as stated in post #7 or carefully melt the plastic with the gun to get a grip at the screw head with a needle head vice grip.
You was supposed to tape those ventsI kind of at my wits end, here. I stripped away all the plastic but the screw will not budge. Not at all. I've been trying for 2 hours and it just won't move. I put a soldering gun on the scrw but that did nothing. Could use a little help. Thanks.
