Inspire 2 Used Motors
South West Florida
I have retired the motors on my Inspire 2 that have about 160 hours on them. These have never been crashed or even had a prop strike and are completely functional. I am selling only the motors, ESC's are not included. $85 USD shipped to your door in the lower 48. As you look at the motors you will notice that a couple of them seem to have the black anodizing color fading.
How was the process of changing the motors for you?
@Florida Drone Supply and @Slavetonone it was actually very easy. The antenna cover screws are extremely tiny phillips head screws and are very hard to find in a carpet :) The process was as follows.
1. Remove the 4 tiny screws holding the antenna cover on, once removed the cover pops off with the help of a paperclip being pushed thru the lower screw hole. The antenna is easily moved to the side to be out of the way, no need to disconnect it.
2. Remove the 4 screws that attach the landing leg to the boom, 2 long and 2 short.
3. Remove the 2 screws holding the ESC mount to the motor mount, not the same size as the short ones from the previous step and are easily confused.
4 Remove the 4 screws holding the motor to the motor mount.
5. Unplug the motor electrical connection.
6 Install the correct rotating motor using the above process in reverse.
Reactions: Slavetonone
Great info thanks!!
I have read a few articles that talk about the motors being held in with glue, so good to see that is not the case. Haha
Reactions: SanCap
JessikaTre
