Inspire customization thread
Hi. I ordered a couple cans of orange blaze. Any special surface preparation to the shiny white plastic on the inspire? Or any other tips you might have to add for a successful application.
Thanks. Dennis
I used goo be gone and let it dry, if you are using Plexi Dip and are putting the screws back in make sure to use some vegetable oil or it will grab and pull the paint off, it sucks because you will need to peel and repaint lol
Thanks. I'm stil a little confused over the battery painting procedure. Did you spray over the clear plastic LED green lights rather than taping them off? And the lights are bright enough to illuminate through the layer of paint?
Yes I sprayed over them, you can see the green outline. I like the way it looks, you can peel the plexi or flexi carefully off them if you want. Pretty easy
i just made some minnor non-permanent customization using 1:144 aircrafts models decals
Reactions: RDTech and Tpoze41
Duracoat is a two part paint that cures hard. It's meant for firearms and adheres to metal and plastic. They do sell a version that comes with a compressed air can to apply it. I personally just used my airbrush.
As far as taking it apart I was able to do it without looking anything up online. I used a heat gun to remove the bottom trim piece. One note is the ribbon cables have a release clip unlike the phantom cables.
The bottom ultrasonic sensor/ camera should cable should be released from the frame not the sensor. It's easy enough to get the sensor off but near impossible to plug back in that way.
One more question about the bottom trim piece. You mentioned you used a heat gun to remove it. I see that the back of the trim piece has tabs on it. So is the function of the heat gun to make the piece more plyable and easy to pull off. And then how easy is it to put back on? Thanks
THE DRAGON by Gustavo Giler.
Painted with permanent markers in his studio in Motañita - Ecuador. He did an amazing Job. I wanted to share it.
http://alikrancito.imgur.com/
Please visit his page at https://www.facebook.com/gustavo.giler
I bought some Blaze Green Plasti Dip. My goal is to aid in keeping LOS. With that in mind, has anyone painted any other parts of the Inspire. The white plastic cover isn't really visible from the ground. Thoughts on painting any parts of the landing gear?
