Inspire firmware displaying problem
I'm having problems after upgrading to 1.4.0.10. I upgraded via 1.3.0.00 as suggested on dji support page and the upgrade completed successfully with the txt file on my SD card. When I go back into the DJI GO app post upgrade and check the "about" option to see the versions the aircraft version now shows 1.2.1.06+ .... (See attached screenshot)
Is this correct or do we have problems to sort out ?
Ok cheers, will try with all batteries and see if it reverts to 1.4......... (Strange it shows a + symbol ????
Hi Aviator..... Problem solved thanks for your idea.... If your batteries aren't updated then you do not get any message in the Overall Status (like you'd think!) but instead the firmware shows version 1.2.1.06+... When you update the batteries (SD card in camera and turn on) the status of the version changes from "1.2.1.06+" to "Unknown" to "1.4.00.10" - there you go another little dji qwerk found... Probably worth saving this thread or editing the title for something better related to the issue? Thanks again.
Reactions: Scotflieger
ziamedicalcenter
