Hi
@Mheight724, the X7 does sit quite low on the
Inspire 2 but it should not be hitting when the gimbal is powered. If the aircraft is not powered on and the gimbal tilts it may hit the ground. Have you replaced your gimbal vibration dampers recently? With the weight of the X7 these dampers get strained over time and it's not a bad idea to replace them over time.
