Lose Landing Gear
Has anyone encountered this problem?
The landing gear keeps getting loose and makes the front right prop hit.
Its happened to me twice now after tightening the t8 screw where it attaches.
Reactions: Phil DeVore
The T8 screw on some I2 can apparently bottom out. You should try to take it out, shorten it by 1mm or so, then put it back, tighten it again and see if helps the situation.
Reactions: noiro
goyalclinicrewa
