No transmission signal
Hi Guys
Any thoughts on this. Everything seems to work ok until I press record and then I get either weak transmission signal or I lose it all together. When I stop recording it come straight back on.
Something may be going on because over the last two days I've been getting weak transmission signal in areas where I previously didn't have any issues.
I've just taken the airframe off and checked all my connections and sprayed them with contact cleaner and changed my iPad cable so I'm hoping everything goes ok when I test later!
I cleaned all my contacts and unclipped the gimbal mount cables under the airframe and reconnected everything and touch wood all good so far
Just curious about 2 things
1 Has anyone had issues with gimbal connection pins or video feed issues?
Thanks.
New Go App update out today that says it addresses transmission issues on the P3 so lets hope its improved things for the Inspire also.
