Olympus-M-Zuiko-Digital 25 mm focusing issue
Hi all
So I bought the 12mm, 25mm and 45mm lenses but the 25mm refuses to focus when tapping on the iPad screen. We also have a Panasonic G7 and it works perfectly!
Any suggestions?
When you go to the camera settings menu and scroll down to the "Lens Proile" tab, does the copter recognize that you have the 25mm lens attached? Make sure the lens is firmly attached to the camera body. If the issue continues I would delete the go app and reinstall, if that doesn't fix it I suggest you do a factory reset with the assistant 2 app.
DarleneSey
