Removed indoor sensor
Hi guys. Today I connected the auxiliary battery. I removed the indoor sensors of the Inspire 1 pro but the drone fails to go into travel mode. The arms are too high or too low. Never in travel mode. Did it happen to you too?
As confirmed above, since the I1 uses the very sensors you have disconnected to determine correct positioning for travel mode, it simply will not function without them!
