Screw for vibration absorbing board
Is there supposed to be a screw holding the vibration absorbing board in place? Where can I get a new one? Inspire 1 with X3 camera
No - that's the access hole for the landing gear worm drive
I disagree... See attached photo... The green circle is the access hole for the worm gear... I am familiar with that. The red circle is something different
I disagree... See attached photo... The green circle is the access hole is for the worm gear... I am familiar with that. The red circle is something different
Ahhh....sorry, looked at the picture too quickly. :(
You are correct, the access hole is the one at the rear. The screw hole you are talking about has nothing in it.
You cannot have a threaded fastening to the airframe as it would negate the floating design and prevent the board from vibration damping.
Thanks! I am curious what the purpose of that hole is then? Would it get used with an X5 mount?
No idea - maybe DJI thought of a transit screw arrangement. To my knowledge there has never been a screw in that position.
The X5 board is a completely different design and uses compression dampening (better) rather than suspension.
No idea - maybe DJI thought of a trasit screw arrangement. To my knowledge there has never been a screw in that position.
Correct, nothing should be in this screw hole. Not sure what it was originally put there for. My only thought would be some sort of anti-drop mechanism similar to that of the P3 and other DJI gimbals.
No need to worry about this.
VanitaYaga
