Slow I2
Did that twice still0 the same. There must be a setting like it's trapped in tripod mode.
Make sure your not in beginner mode.
If this does not work do as follows and it should solve it.
Rebind original Remote, calibrate sticks and fly, It should be fine.
Then rebind Cendence as Master and again calibrate the sticks, note you must also calibrate the two top wheels, focus wheel and the side sliders by moving them through their full swings when you are doing the sticks even though it may not be shown.
Make sure side sliders are at minimum but should be fine after this.
