symptoms of a bad ncore..........
in the steps, nothing on dd-dd-dd-dd-dd-dd-dd-dd- and all motors are tbeeping........and i have no lights.......did this bird im trying to fix drown in water
Step 3- Update the Aircraft 1. Ensure the remote controller is powered off and then power on the aircraft. Upgrade will begin automatically after aircraft is powered on. 2. It will take approximately 25 minutes to complete the firmware update. The camera will sound a short pluse of "D-D-D-D" beeping sound to indicate the upgarde is in progress and sound a “D — DD” beeping sound to indicate the update is complete with success. 3. Check the upgrade status by opening the “.txt” file that is automatically generated after the update. The update is successful if the text “result: successful” is in the document. Try upgrading the firmware again if the text “result: failed” is found or the gimbal sound a long beep sound.
goyalclinicrewa
