X5 video "lag"
Hello, my name is César Oliveira, I'm from Portugal.
I recently bought the dji Inspire Pro with the X5 camera, I noticed that when I move the camera a little bit faster the image does some kind of "lag", it's not fluid, it's hard to explain but I can´t move the camera fast without doing this effect, I really don't like it.
with the Osmo is the same, it's a little bit worse because I'm closer to the objects.
I used the shutter speed at 50, F8 ISO 100 at this little video:
*On my 27 inch monitor its worse than my 15 inch mac.
Can anyone help me?
Thank you,
César Oliveira
Are you talking about the little jumps when panning? It looks to me like a frame-rate mis-match. Is your output a factor of your shutter speed (50fps, 25fps etc for a shutter speed of 1/50)? If you are recording at 24fps or 60fps with a 1/50 shutter then it could cause this.
Yes, the little jumps.
No, I used the shutter twise the frame rate.
25fps at 50th.
Tomorow I will try shoot with less sharpheness, I will try D-Log.
Thank you rilot.
César Oliveira
adidasCampusShoes
