Battery Mod Info
No, 1 x 5200 6S Multistar . Next test 2 x 2200 6S Zippys. After that 2x 5200 3S Traxxas in series.
I predict the 2200's will still be top dog but post those results! I could be wrong.
Where are you mounting the single and doubles? That can make a difference.
My next test since I'm Thunder Power poor at the moment will be with 2 nano 2650's. That holds promise I think to get beyond my 27:36 mark with the 2200's.
The brand is Multistar. Mounting them like Damon, on the sides. The 1 x 6S under the belly. In general, mounting them is a pain. So will only do when I need extra flight time. Receiving my V2 tomorrow. Lets see how that performs.
Zippys 2 x 2200 mah NOOOOOOOOOOOOOOOO Good ! Even the 40C Versions that I have. At 15% all cells in the red. Only 24 mins flight time :-(
Zips were down to 3%. So for now, Multistars are much better.
They weigh 370g each. Mounted on the sides, like you did. Main is TB48, yes.
Just tried 2 x 5200 3S Traxxas in series. No good either. 23 mins. Was windy though.
Next try 2 x 5200 6S Multistars.
So far best has been 1 x 5200 6S Multistar.
Flying X3.
Flying X3.
What time did you get with the 6S 5200? Two of those I think will be way too heavy.
I got 27.10 mins. But it was cold and a little windy. So I guess there is some improvement possible.
They may be heavy, but worth a try...;-)
Definitely worth a try! Please post back your results. It's s community effort now! :)
I'm still confused by the 6S 2200 results, but maybe it's just the difference between the Zippys and Nano? I got 27:36 to 10% on the nano's but you only got 24min.
How are you planning to mounting the 6S 5200's? Be careful with props. I had to change mount position with my 5200 3S's as they are so much bigger than the others. Things looked ok but then I did an inside landing gear transition and it was clear I would have punctured the packs in flight if I had gone out that way on landing gear up.
Reactions: turbodronepilot
Will try to mount them under the arm. 1 on each side. If results are good, will look for a better mounting possibility.
Want to try the TP Lihv but cant find them anywhere in Europe...
some new changes. new battery tray.
Been testing it this afternoon, everything seems fine, will carry 4 6s next time.
2 x 2200 on the side
2 x 1550 under the main unit.
CodyF
