Best Gain Settings?
Hola!
I'm in Mexico working with someone else's M100. I tried a first flight and it was all over the place. I checked the gains and they were all at 4o or 50. I assume they are way too high based on my phantom settings and the flight behavior, though I'd love some input on best gain settings for cinematic shots. Thank you!
Sent from my SM-G930V using InspirePilots mobile app
Hola!
You might first try the EXP settings, slide them down in the GO app. The default gains should be ok for most cases. You really have to know the craft to mess with gains.
How's the simulator behaving? Same thing?
You could use the simulator to check out various settings with EXP and stick filtering (android) or sensitivity (IOS) .
I have an Inspire1 by the way but the Matrice100 uses the same GO app.
Trezoriostat
