Calibrate Every flight or not to Calibrate that is the question?????
Looking for feed back from people with 100 flights or more. I have been reading that you should Calibrate every Flight or when you move to a new spot. Then there is the other side that says Only Calibrate 1 time in a field that you know has no under ground metal and to only re-calibrate if you move 100 miles or so. So what do the most experienced pilots here do?
Please read this thread (which is why I made it a sticky)
To all new Inspire owners and new forum members | DJI Inspire Forum
This has been covered so many times on the forum - please do a search and make your own mind up.
I have gone over the theory behind why I consider not calibrating at every new location is best many many times previously.
I do not want this to become another "calibrate/don't calibrate thread"
Reactions: Scotflieger
VanitaYaga
