cant get my RTH to set to my RC
Hm, do you mean the DJI Pilot app? I have version 1.1.0 and still get the message that my RC has a too weak GPS signal to set the RC as home point.
@1n5pired @Wesmann
You will find that the GPS receiver in the RC is not that good. If you get a weak GPS signal measure when trying to set the Home Point, lift the front or the RC and point the antenna towards the southern sky (or north in southern hemisphere) for 10-15 seconds. Then try to set the HP again and it should work.
Reactions: The Editor
Sometimes your homepoint is allready set and when you want to set it by yourself it doesn't work.The red symbol is covering the yellow homepoint.Try to land and start agian without going away.Try to set homepoint by yourself.Maybe this works.If not fly away 10 mtr(30 ft) and try again.I've found out that this works .
memoshieldcost
