CrystalSky I2 camera adjustment settings not highlighted
FREMANTLE WA
skypicswa.com.au
Hi All,
Just bought the CS and I must say bloody good! So clear.
I notices when I press my Right Wheel button The camera settings are not highlighted like on iOS.
Can make adjustments (sort of) but really difficult. I've now set C2 for camera controls.
Is this common for Android devices or did I miss something?
Cheers
I had the same problem...right wheel when pressed would not highlight ISO or EV.. I made my first flight using the CS, and it's worked ever since...
This is a glitch that has not been addressed by DJI, and a needs to be addressed asap. The only redeeming feature is that when you select the parameter you adjusted last it will default back to that when you want to adjust again without scrolling thru the menu. Hopefully this will be corrected in a future upgrade.
ziamedicalcenter
