DJI Go 2.5 Updated
Just to let you all know the geofencing is actually working flawless for me. Go to their website and authorize your account. When you approach a geofence zone it pops up on your screen saying so and when you agree to the terms it allows you to fly for 24 hours before you get another warning
If your account is not authorized it will state it's a no fly zone and not let you fly at all.
I've tested this in many zones yesterday and today with no issues at all.
If your going to fly where there is no internet you can open a geofenced zone for 3 days through the website
I'm also using only firmware 1.5 on my drone. Not 1.6 without issues
I thought you can only do this with the beta android firmware 1.09.02.01? How is it that this is working on 1.5? Is this information still valid or has it changed with recent firmware releases sine January?
There are still major rendering problems so use it at your own risk. Why do you think it has taken months and months and still not been released?
The polygons are still not rendering accurately and are unpredictable.
Reactions: eldorado
<integer>817278603</integer> 2.8.1
<integer>817508323</integer> 2.8.2
<integer>817522546</integer> 2.8.2
<integer>817572162</integer> 2.8.3
Ok, so let me try and make this as simple as possible for everyone. I'll show you a way to download ANY version of DJI go that you want. Its a bit complicated but will allow you to choose which version you want to install.
You need a PC or Mac with ITunes installed.
This only works for IOS Devices...
Step 1: Download, install, and launch Charles. Click Grant Privileges and enter your administrator password. (Charles is a proxy program that allows you to monitor the traffic between ITunes and apple servers)
Step 2: Download DJIGo from iTunes, and watch the download activity in the Structure section inside Charles. You should see a “buy” server.
Step 3: Right-click on the “buy” server and click Enable SSL Proxying
Step 4: Stop the iTunes download.
Step 5: Search DJIGo again in iTunes to bring up the details page, and download the app again. Cancel the download again
Step 6: Click the disclosure triangle by the “buy” server and click buyProduct.
Step 7: Click the Response tab, right click on buyProduct and click Export. Select the Desktop as the Export location, select XML for format, and click Save.
Step 8: Open the XML file using a text editor, and scroll down to locate the following line:
<key>softwareVersionExternalIdentifiers</key>
Under that line you should see a list of numbers similar to this:
<integer>814445173</integer>
<integer>814493632</integer>
<integer>814584509</integer>
<integer>814566170</integer>
<integer>814760906</integer>
<integer>815084483</integer>
<integer>815086904</integer>
<integer>815112170</integer>
<integer>815288287</integer>
<integer>815611197</integer>
<integer>815615585</integer>
<integer>815764145</integer>
<integer>815878759</integer>
<integer>815949783</integer>
<integer>815876501</integer>
These are all of the versions of the app, starting from oldest to newest.
Copy the version number that you wish to download. You’ll have to do some guess and checking if you’re looking for an exact hit on a specific version. Close the text editor.
Step 9: Back in Charles, right-click on buyProduct and select Edit.
Step 10: Click Text and find the following line near the top of the page:
<key>appExtVrsId<key>
Underneath that text, you’ll see a numerical value inside <string> tags. Paste the value you copied in step 8 to replace the value that’s displayed. Once you do that, click the Execute button at the bottom of the screen.
Step 11: Scroll down under the Response tab and you should see the bundleShortVersionString. Underneath that, you’ll see the actual numerical version of the app that you keyed in on. You can repeat this process until you hone in on the specific version that you’re after.
Step 12: Right-click on the last buyProduct in the list under the “buy” server, and click Breakpoints.
Step 13: In iTunes, search for the DJIGo app again to refresh the page, and click the Download button to initiate the download again.
Step 14: Back in Charles, you may see the Charles splash screen appear briefly. Click Edit Request → XML Text, and paste the version ID that we copied in step 8 under the <key>appExtVrsId<key>. Click Execute again.
Step 15: You’ll see another breakpoint, just click Execute again.
Step 16: Check iTunes, and the download should commence and complete.
Step 17: Click the My Apps tab, and you’ll see your downloaded app. It should be the older version of the app. You can right-click and select Get Info to verify the older version number.
Step 18: Connect your iPhone to your Mac or PC, and drag the app icon for the older version of the app to your iPhone. You’ll need to make sure that any newer versions are uninstalled from your iPhone or Ipad before you can install the older version.
Step 19: Close and uninstall Charles once complete.
Make sure to disable auto updates so the newest version won't automatically download after your done.
Seems like someone should download all the old versions and sell them for $5. It would be worth it to avoid all these steps.
You cannot do that. They are account specific, and will not work on any other device except for the account that was used to download it. Would be nice though.
CodyF
